setting up HH190 as a second MIG unit
发表于 2021-8-31 22:24:02 | 显示全部楼层 |阅读模式
i just bought a HH190 to get a little more power for my hobbyist welding projects.  i just  have set up  the smaller lincoln weld pak 100 mig set up with .025 L56 wire.  i figure this will just be dedicated to sheetmetal projects and will share the tank with the HH190 and i want to set the HH190 up for larger stock.  i have  half a 2lb roll of the .030  L56  wire left so i figure i will try this in the HH190.  this will probably be gone soon since i will be playing alot with the HH190.  once this is gone i was thinking of putting .035 wire in the unit.  what is everyone else doing? and is there a difference between the hobart wire and the L56 wire?  i have over15 yrs of using the L56 and have no  complaints with it all but i am always ready to try something new.   thks bobbobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
GMT+8, 2026-1-1 06:01 , Processed in 0.108115 second(s), 18 queries .
