Sa-200 ?
发表于 2021-8-31 22:23:59 | 显示全部楼层 |阅读模式
I have 2 sa-200 one is a 1978 with the f 163, the other is a 1948 with a f 162,the 78 needs shunt coils and the 48 I think has a bad armature.now my question is can I use the armature out of the 78 in the 48?the 1948 is a code 1228the 1978 is a code 8023
Reply:I think you will find that they are different.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:I just got the 48 short hood today was told it hadnt been ran in 2 years, I cleaned the points and carb put fresh gas in and it started up and runs fine very little smoke. I would really like to get it welding,it looks like the 78 will be the easyest to fix, I have it tore down and waiting for the funds to buy the shunt coils.I have another sa-200 located and have been told 2 stories about it one told me it had a bad Mag. another said it had a bad motor
GMT+8, 2026-1-1 07:49 , Processed in 0.071248 second(s), 18 queries .
