Need parts for Lincoln Weldanpower
发表于 2021-8-31 22:23:59 | 显示全部楼层 |阅读模式
I have a bad rectifier on my Weldanpower. I am looking for a similar  machine that someone would be willing to part out,or just sell me the part. Does anyone know where to find such a part [preferably used]? The part # is M15499 The possible  codes # from any Weldanpower 225 g7 areas follows 9316,9317,9340,9444,9445,9653,9654,9656,9720 and 9721. Any match will work.Thanks David aka zayzay
Reply:Hi Ya zayzay you may want to post that question down in the Manufactuers Section-LincolnLast edited by specter; 03-18-2009 at 08:36 PM.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Stumpf's had a lot of these machines around. I am sure that they can find a used rectifier for you. Give them a call. 618-566-4733
Reply:According to Lincoln's website, M15499 is a reactor not a rectifier. If you are looking for a rectifier, I believe those units had individual diodes that can be replaced. However if you need the reactor you will have to find a used one, they are no longer available from Lincoln.Gary Haunemail  [email protected]  http://haunsystemsrepair.com
GMT+8, 2026-1-1 07:31 , Processed in 0.102602 second(s), 18 queries .
