powerave 350/450/500 wire feeder
发表于 2021-8-31 22:23:56 | 显示全部楼层 |阅读模式
hi, i just bought a powerwave 450 but miss the synergic 7 wirefeeder. - is it possible to connect this to LN 25 or similar LN product?- can i use other wirefeeders?- is there a slight chance of finding a synergic 7 wirefeeder used?  (or is this rare?)thanks,
Reply:I have a Powerwave 450 Robotic that I tried to setup on a semi-automatic wire feeder.  I consulted with our local Lincoln engineer as well as tinkered myself with really no results.  Lincoln states the only compatible wire feeder with the power source is the synergic 7 wie feeder.  I did try an ln 7, however the "Synergy" communication that is required between the wire feeder and power source made that attempt useless.  The only thing I did get to work was modifying the robotic synergy 7 wire feeder to run of a whip and be actuated off the trigger.  Made a real compact wire feeder though.  At the time, I never thought of using an ln 25, but perhaps using the across the arc ability would work, but then you would be limited to purely CV operation.Just a word to the wise, I know of a guy here who electrocuted himself trying to accomplish the same thing with a ln 7.  They gave up after his death, they were just handed down a $100,000 fine a couple of months ago.  Just make sure the power is disconnect if you open up the case.
GMT+8, 2026-1-1 07:38 , Processed in 0.079261 second(s), 18 queries .
