Anyone using a Hobart or Miller 6-50P Plug - Part Number 219258
发表于 2021-8-31 22:23:49 | 显示全部楼层 |阅读模式
If anyone is using the Hobart or Miller straight 6-50P Plug, Part Number 219258, I would appreciate if you could measure the size of the hole the cable goes through on the back, I want to make sure it will be big enough for the cable I am currently using.I will be using the plug for my 220V Heater, not one of my welders, don't want to use a 90 degree plug.Thanks.Working on cars and bikes is my hobby, learning to weld the pieces together is my quest.
Reply:Originally Posted by DavidSimIf anyone is using the Hobart or Miller straight 6-50P Plug, Part Number 219258, I would appreciate if you could measure the size of the hole the cable goes through on the back, I want to make sure it will be big enough for the cable I am currently using.I will be using the plug for my 220V Heater, not one of my welders, don't want to use a 90 degree plug.Thanks.
Reply:Ok, here is the bad news.....As you can see, that plug is a molded plug that you cannot take apart to wire on to an existing bare wire cord....It's an exact factory replacement for several dual voltage machines, not just the Hobart....So forget buying it expecting to install it on bare cord....You could buy the whole cord and plug, tho.The OEM cord on my Hobart measures exactly 5/8" OD...Google up just the part # in google images and you will see it is exactly like mine in that it is designed to screw onto the end of dual voltage OEM cord where at the screw junction it gets converted to 4 prong small spade to 3 prong 6-50....But no way can you open it up and attach it to bare cord.Last edited by wornoutoldwelder; 11-06-2015 at 07:58 PM.
Reply:http://www.gordonelectricsupply.com/...FYRFaQod01cEOAThe link above is about the best you gonna do attaching a straight NEMA 6-50 plug to a bare cord.....It ain't cheap, but believe it or not it's cheaper than most other offerings.It will accept from .32" to .91" OD cord.
Reply:GEEZ, $50+??   HTP sells a Cooper brand one that will surly accept beefy wire for around $12. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by OscarGEEZ, $50+??   HTP sells a Cooper brand one that will surly accept beefy wire for around $12.
Reply:My bad, I missed that part lol.  Yea I have that same adapter for my Millermatic211. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Thanks for the tips everyone, I am going to check out that PASS & SEYMOUR plug, it looks like it will work for me.Thanks again.Working on cars and bikes is my hobby, learning to weld the pieces together is my quest.
Reply:Here is a Galco plug for just 38 bucks that should work for you.https://www.galco.com/buy/Arrow-Hart...-Devices/5710N
Reply:>>Here is a Galco plug for just 38 bucks that should work for you.>Dave, do you mind if I ask why you want a straight plug?>Dave, do you mind if I ask why you want a straight plug?>but consider hard wiring the ceiling heater to the box in the ceiling at no cost>but consider hard wiring the ceiling heater to the box in the ceiling at no cost>Maybe you can advise me on barrel stove for me and my mud truck bud up the hill?...I'm thinking two 30ish gallon steel barrels stacked one above the other with removable banded ends and lined with fire brick in bottom barrel Here is a Galco plug for just 38 bucks that should work for youHere is a Galco plug for just 38 bucks that should work for you<<I just picked one up tonight, it is perfect for my needs, thank you sir for the recommendation.You are my hero.
GMT+8, 2026-1-1 07:31 , Processed in 0.074180 second(s), 18 queries .
