Ln 25 work with my miller bobcat 250
发表于 2021-8-31 22:23:49 | 显示全部楼层 |阅读模式
Hello, I'm looking at a ln25 to hook up to my miller bobcat 250 and just making sure they are compatible. And anything I should keep an eye out for? The guy is asking 400 for the ln25.Sent from my SAMSUNG-SM-N910A using Tapatalk
Reply:Should work just fine. Here’s how you hook them up. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Ok thank you Sent from my SAMSUNG-SM-N910A using Tapatalk
Reply:It’s been just about 100-years since I ran a bobcat, does it have CV?Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:You're good to go.  Have used one off my Bobcat 225G Plus in both CV and CC modes.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Might want to kick that ground clamp over a little closer to what your welding on. LOL!
Reply:Originally Posted by gundog77Might want to kick that ground clamp over a little closer to what your welding on. LOL!
Reply:Wish I'd known about the concrete wire. I would have welded the cracks instead of using the grout. MY Bad!
Reply:Originally Posted by gundog77Wish I'd known about the concrete wire. I would have welded the cracks instead of using the grout. MY Bad!
GMT+8, 2026-1-1 07:49 , Processed in 0.070574 second(s), 18 queries .
