trouble with fogging up my helmet and safety glassess when welding
发表于 2021-8-31 22:23:47 | 显示全部楼层 |阅读模式
When I am welding I have trouble fogging up my helmet lens and especially the safety glassess if I am wearing any.(confirmed hothead).The colder or more confined the area the worse it gets.I have tried anti-fog solution but the stuff I had seemed worthless.Thanks for any advice guys.
Reply:There is some stuff called "cat crap".  Seriously.  It's a waxy paste that you buff out,  worked well while sking.
Reply:Breathe only thru your nose, it creates a downdraft forcing the warm moist air down.                                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Don't breathe when you weld. Sent from my iPhone using Tapatalk
Reply:You could also try a respirator.   The 3m respirator I have vents straight down so doesn't fog up lens.  Check out a motorcycle shop.  They always have good anti fog stuff for bikers.
Reply:Originally Posted by JakedasnakeWhen I am welding I have trouble fogging up my helmet lens and especially the safety glassess if I am wearing any.(confirmed hothead).The colder or more confined the area the worse it gets.
Reply:Hey you guys are the best.Great ideas.Glad to know someone else has had trouble with fogging up their helmet.I will have to find if an air flow system is available for my Jackson Wh70 helmet
Reply:i found this stuff inside the box when i bought a military surplus gas mask. it's made by msa and works pretty good Attached Imagesi.u.o.e. # 15queens, ny and sunny fla
Reply:"Resp-O-Rator" Get one.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by Burpee"Resp-O-Rator" Get one.
Reply:My Miller Cool Band helps some. Warm the helmet gently with a hair dryer, Cat Crap works, but smears the lens. For my snowmobile helmet, I have a face piece that covers my nose and mouth ducting my breath away.
GMT+8, 2026-1-1 07:49 , Processed in 0.103252 second(s), 18 queries .
