MIG wire differences ?
发表于 2021-8-31 22:23:44 | 显示全部楼层 |阅读模式
I'm wondering what the diff is between ER50-6 and the ER70S-R wire ?
Reply:Sorry to bump.
Reply:where did you find ER70S-R?  never even heard of it. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by panelI'm wondering what the diff is between ER50-6 and the ER70S-R wire ?
Reply:If it is ER50-6, it is Electrode Roll or Rod 50,000 psi tensile strength - 6 is the amount of deoxidizers.  Not sure if that is a solid wire or not.ER70S-6 is Electrode Roll or Rod 70,000 psi tensile strength Solid wire - 6 is the amount of deoxidizers. -2, -3, -6 are all very common.So the primary difference is strength.
Reply:Originally Posted by Oscarwhere did you find ER70S-R?  never even heard of it.
Reply:Originally Posted by AxisIf it is ER50-6, it is Electrode Roll or Rod 50,000 psi tensile strength - 6 is the amount of deoxidizers.  Not sure if that is a solid wire or not.ER70S-6 is Electrode Roll or Rod 70,000 psi tensile strength Solid wire - 6 is the amount of deoxidizers. -2, -3, -6 are all very common.So the primary difference is strength.
Reply:Actually ER50-6 has exactly the same chemical composition and slightly better mechanical properties as ER70S-6.I did a search and found out it is according to a Chinese standard (GB/T 8110)http://www.nhzjj.com/asp/admin/edito...8165337422.pdfSo in theory they are almost the same thing.
Reply:Originally Posted by taz00Actually ER50-6 has exactly the same chemical composition and slightly better mechanical properties as ER70S-6.I did a search and found out it is according to a Chinese standard (GB/T 8110)http://www.nhzjj.com/asp/admin/edito...8165337422.pdfSo in theory they are almost the same thing.
Reply:That could explain alot.  The Chinese equivalent of 70k psi is 50k psi.  Now it all makes sense.
Reply:Lol!Actually it means MPa.
GMT+8, 2026-1-1 07:48 , Processed in 0.099246 second(s), 18 queries .
