spot nozzles for miller 252
发表于 2021-8-31 22:23:43 | 显示全部楼层 |阅读模式
I just got a new miller matic 252 with the spot timer setup on it.but you don't give you the spot nozzles with the machine, you can'teven get them. is it me or is this assnine to put this in a welder and not have the ends to do the job right. my old millermatic 35 came with allthe ones you need ( inside-outside-flat ). Anyway does someoneknow where i can get some for a m-25 gun.  miller dosen't know.also i have a spool gun setup for a millermatic 35 for sale if anyone is interested.   [email protected]      thank you
Reply:You can convert the M25 frontend to use Bernard Centerfire parts and then use a Bernard spot nozzle on it.  Contact www.bernardwelds.com for the adaptor part number and for the diffuser, insulator, tips and nozzle part numbers.  It's not that expensive to convert and once you use the Centerfire frontend, you'll probly never want to go back to a regular Miller mig frontend again.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33You can convert the M25 frontend to use Bernard Centerfire parts and then use a Bernard spot nozzle on it.  Contact www.bernardwelds.com for the adaptor part number and for the diffuser, insulator, tips and nozzle part numbers.  It's not that expensive to convert and once you use the Centerfire frontend, you'll probly never want to go back to a regular Miller mig frontend again.
Reply:Don't feel bad I bought a Power MIG 255XT and Lincoln Electric  didn't make any spot nozzles for that machine. They only had them for their small little 115 V migs.As Homer Simpson would say .........Doooh!Shame on  Miller & Lincoln Electric
GMT+8, 2026-1-1 07:32 , Processed in 0.093234 second(s), 18 queries .
