Hardinge Cataract Quick change Restoration Project
发表于 2021-8-31 22:23:40 | 显示全部楼层 |阅读模式
I realize this is mostly a welding forum however lots of you work in or around machine shops with lathes etc. I am in the process of restoring a 95 year old metal lathe built in Dec 1916 by Hardinge Bros of Chicago. You can view a thread about the project here  If you wish to see pictures of the restoration project you can see them here  With this in mind if anybody out there comes across either complete machines or parts that will fit my machine please let me know. You can email me at haroldmulder(@)hotmail.comThere were very few lathes of this model built by the company therefore parts are hard to find.Thanks for any assistance anybody might be able to lendPS I'll attach a picture of what the lathe looks like minus the drive motor.Harold Mulder Attached ImagesHarold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Worked at a couple of places that had newer Hardinge toolroom lathes. Amazing machines the nicest I have ever used, they could even make me look pretty good with the tolerances they would hold. LOLNice find and you are doing a real nice restoration job.
Reply:love the restore. quality
Reply:Thanks for the kind words. If all goes well the Headstock will be mounted by the end of the weekend.Harold MulderHarold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Hardinge are great machines, my next spindle machine. I want a horizontal I want to be abel to hog!!! metal once in a while. I know a real metal hog is a big Cincinnati bt check this out: http://www.califsawdustman.com/myworkshop.htmReally sweet vertical, and horizontal in the same machine.What electical motor are you looking for is that an AC machine, was it a GE motor, I run across those every oce in a while.
Reply:Actually already have a motor and assembly for this. Motor that came with the machine was a newer GE motor. Have not yet got to that area for cleaning and restoration. Once the headstock is installed then we'll install the overhead motor supports with the upper pulley assembly and the rewired motor and switch.Harold MulderProject pictures hereHarold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
GMT+8, 2026-1-1 07:31 , Processed in 0.124519 second(s), 18 queries .
