pipe expander help
发表于 2021-8-31 22:23:39 | 显示全部楼层 |阅读模式
hi all looking to make a pipe expander is for use in exhaust systems. my question is if I can help with photos or recommendations of how to make me watch videos online and I have an idea but I wanted you can advise me.  thanks
Reply:no nee t make one, they are dirt cheap. You can likely get one at harbor fright for ten bucks.Personally, I just butt weld them, easier, and I have never had one come apart.
Reply:http://www.harborfreight.com/small-t...der-37352.html
Reply:Those aren't used to expand a pipe so another will slide in. They are for reshaping one that is already expanded.TA PAK 5XRTA 185Lincoln Wirematic 250
Reply:thank you for answering me since I want to arm the few tons hydraulic cylinder and hydraulic pump? pipe is for 1 3 / 4 2 "2 1 / 4 2 1 / 2 inches
Reply:Originally Posted by 2rodsThose aren't used to expand a pipe so another will slide in. They are for reshaping one that is already expanded.
Reply:I used one years ago and most of the fingers broke and bolt stripped. Maybe they are better now but I doubt it.TA PAK 5XRTA 185Lincoln Wirematic 250
Reply:Originally Posted by BistineauIt says in the website"for expanding pipe for exhaust pipe work".
Reply:You might want to look at the Lisle impact driven expander. Model 34400 Exhaust / Tailpipe Stretcher, Stretches All Pipe Including Stainless Steel.http://www.lislecorp.com/divisions/p...s/?product=191You can also get them as a kit 17350:http://www.lislecorp.com/divisions/p...s/?product=565The 32500 and similar remove clamp grooves and rounds out pipes. This is basically like the HF unit but better quality. Not what your looking for.http://www.lislecorp.com/divisions/p...s/?product=177
Reply:Those first 2 look like they would work great. Decent reviews on them also. May just get that set.TA PAK 5XRTA 185Lincoln Wirematic 250
Reply:You can test circuits with this one.http://www.google.com/products/catal...ed=0CG4Q8gIwAA
Reply:WOW! Technology is fantastic!!!!  HOW DO IT KNOW?AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and  Do all C-4 band saw ,  Always adding.
Reply:I lolTA PAK 5XRTA 185Lincoln Wirematic 250
GMT+8, 2026-1-1 07:47 , Processed in 0.119573 second(s), 18 queries .
