查看: 2|回复: 0
wiring a cut 50 dx
发表于 2021-8-31 22:23:39 | 显示全部楼层 |阅读模式
i needed a cheap plasma cutter and bought a cut 50 dx.....its both 220 and 110 and is self sensing for voltage,  i want to wire it 110v tonight and the directions have only the power input diagram for 220....it shows   L....brown wireN.....blueG..... Yellow/green and that goes to Grndcan anyone confirm that for a 110v three prong plug  i will use the Brown for the hot lead, Blue for the Neutral and Green for the ground.  thks bobbobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:That is correctEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:thanks bobbobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
GMT+8, 2026-1-1 07:31 , Processed in 0.105969 second(s), 18 queries .
