SA 200 Parts and age
发表于 2021-8-31 22:23:37 | 显示全部楼层 |阅读模式
I just got an old sa 200 and dont know the age .I also need a water pump for this welder .can anyone help?
Reply:http://www.billswelderrepair.com/   if you look around on this site, you can figure out the age and find a few parts for the ole SA'sHillbilly Fabworks
Reply:thomasg990,Here's http://content.lincolnelectric.com/p...of_Machine.pdf how you can tell the age of your unit based on its serial number.I would check with Bills Welder Repair first as BNF has suggested but here's an ebay example of water pumps for the SA200 Continental to give you an idea of possible costs.  I have no idea if it's a good 'going' price or not.http://cgi.ebay.com/Lincoln-Welder-S...3A1%7C294%3A50MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Just in case you are wary of EvilBay you can look here:http://www.weldmart.com/CONTINENTIAL...PUMP%20MST.htmGordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Stumpf's has water pumps for all years. $105.  www.stumpfweldingsupplies.com/200parts.html
Reply:The 110 volt recpticle on the front dosent work . Is there a way to  get it going or is it not worth the trouble ?
Reply:The plug on the front of sa 200 is dc current so you may burn out switches and or worse  on any ac tools you plug into it.                FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:most if not all of my power tools are 110 ac/dc . They are a little more expensive but needed for that dc power .I wish I could get the recepticle working . anyone got any Ideas .
Reply:pics ..pics...lets see the pics.....we like picsIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
GMT+8, 2026-1-1 07:38 , Processed in 0.191045 second(s), 18 queries .
