Largest electrode used on a 250 amp engine drive
发表于 2021-8-31 22:23:36 | 显示全部楼层 |阅读模式
I tried a 1/4 7024 the other day just to see how it did on my Ranger GXT. It did quite wellbut i would like to know what is the largest electrode you have used. Thanks, Bart.
Reply:3/16 8018 on a ranger 250.   Its the limit for me and the machine.Did you run the 7024 on AC?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I have a Lincoln weldan power 225 G7 and the biggest I ever ran was 5/32 7024 and it ran quite good.I tryed air arcing with 1/4 rod and it didn"t seem t have enogh umph to us it real good but it may have been due the amount of rust and not enough air pressure cuz it would run good for a minute then cold????so  will just go get smaller rod and work it like that maybe some 3/32.If it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:Lincoln sez 1/4" 7024 starts at 315 amps DC or 350 amps AC.3/16 starts at 220 amps up to 280.Try arc air with the G7 with 3/16 rod, it should do it.Here is the linkhttp://content.lincolnelectric.com/p...ature/c210.pdfDavid Real world weldin.  When I grow up I want to be a tig weldor.
Reply:David, I ran the 7024 on DC+ just to see what would happen then on DC-. I'm just trying to get a feelfor the capacity to know what it's limits are. Thanks, Bart.
Reply:lol thats what I ment to say 3/16 not 3/32......lol my badIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:Try the 7024 on AC, it runs even better.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:David, I'll try that. I'll also get some thicker stock. I used 1/2 plate and welded a T-joint. Later, Bart.
Reply:I've run 3/16  7018's on my GXT at times.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by bartI tried a 1/4 7024 the other day just to see how it did on my Ranger GXT. It did quite well
Reply:Different forum. Same people. Later, Bart.
Reply:Was told by a Lincoln Rep not to use over a 5/32  on  a 225 DC Weldanpower (onan engine),if you wanted it to last.
GMT+8, 2026-1-1 07:48 , Processed in 0.184646 second(s), 18 queries .
