Lincoln 300D High Idle problem
发表于 2021-8-31 22:23:35 | 显示全部楼层 |阅读模式
Hi All,I've tried to find a similar problem on the WW forum without any success...too many posts!My high idle doesn't kick up when using the 120 Volt outlet. It works fine when welding and the high idle switch also works but my grinders etc. do nothing. (It did work occasionally for a while then quit altogether.) Any thoughts? Hope it's not the circuit board!Rotavia
Reply:We use certain grinders with our welders that won't kick up the high idle either.  It's the metabo that ramps up the rpms.  All we do is strike an arc to bring up the idle then it will work.  I hope this makes sense.Local 597 PipefittersCertified stick and tig pipe welderLincoln Ranger 305g - for saleMiller 185 migMiller Digital Elite
Reply:Thanks for the reply. My grinders....even mini grinders-always kicked up the high idle until just recently. Might have to take it in to the dealer!
Reply:From the manual troubleshooting for the auto idle:The Auxiliary Power Load is Turned ONPower Load Too SmallTry Load Above 150 WattsEngine Does Not Pick Up Speed1. Check Continuity of Idler Solenoid Coil(8.5-9.0 ohms) and Replace asRequired.2. Check for Jamming of the IdlerSolenoid Mechanism.3. Check for Continuity of CurrentTransformer (Toroid). Replace asRequired.4. Check Idler Circuit Wiring and Repairas Required.5. Replace Idler P.C. Board.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane,You're the man with the answers...Pardon me for  hi-jacking this thread for a moment.  I have a 300D also, and frequently wish that the machine would not idle so fast.  I'll be working, and before I can change rods and get set for the next pass the welder has idled down.  Is there a way to adjust the delay that before the engine idle's down?Thanks...Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:The high idle auxillary pickup "toroid" has failed. About a 15 minute fix at a repair shopAnswer to the quick to idle post, no that is a preset delay and cannot be adjusted
Reply:Thanks Cruizer, I was afraid that's what the answer would be.Again, apologies to all for hijacking the thread. Originally Posted by CruizerThe high idle auxillary pickup "toroid" has failed. About a 15 minute fix at a repair shopAnswer to the quick to idle post, no that is a preset delay and cannot be adjusted
Reply:Originally Posted by A_DAB_will_doDuane,You're the man with the answers...Pardon me for  hi-jacking this thread for a moment.  I have a 300D also, and frequently wish that the machine would not idle so fast.  I'll be working, and before I can change rods and get set for the next pass the welder has idled down.  Is there a way to adjust the delay that before the engine idle's down?Thanks...
Reply:Thanks for the info folks....I'll test the toroid and go thru the troubleshooting list soon as I have some down time!
Reply:I pressure washer my welder and that seemed to fix the problem! It wasn't that dirty either.....must have been a piece of grit on the circuit board or somewhere.......
Reply:. . .or pressure washing it caused a poor connection to be 'corrected'.  You might want to go through and check all the connectors for corrosion and/or loose terminals if you haven't yet.Good to hear it's working again - hope it stays that way for you.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 07:31 , Processed in 0.107983 second(s), 18 queries .
