Ulitimate farmers Welding cart.
发表于 2021-8-31 22:23:31 | 显示全部楼层 |阅读模式
I ran to tractor supply yesterday to pick up a new pair of gloves before work on Monday. I was browsing the deal bin cause its a crime if you dont at tsc. Low and behold they had 4 off-road swivel casters on clearance for 11.99 when they're normally 49.99. Then the great idea came to me make a cart for my buzzbox so I can wheel it outside the shop. While I was on the drive home I thought "Damn I should picked up tires for my o/a cart. Then the bulb clicked to put both on there. So between the scrap from the man lift and flatbed its started. Im going to put a shelf for rods, tips, strikers, etc. Then hangers for the leads and hoses. I welded the rear swivel caster solid after it toppled over while testing it in the limerock sand mix behind the shop. Here it sits.
Reply:swamp; looking good. and you got those caster's cheep. even better.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docwelderswamp; looking good. and you got those caster's cheep. even better.
Reply:A useful, no-nonsense rig, and at a sensible cost.  Nice.      -Marty-
Reply:Looks like it will do what you need. I would add another chain or something to keep the bottles from kicking out on the bottom.
Reply:how does it do outside with those wheelsThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:Good. Just a lil tough for my scrawny a$$ to pull around. Im going to weld folding handle so im pulling from the bottom and not the top
Reply:Originally Posted by tackitNice cart swamp, have you had OSHA inspect it.
Reply:Does having all four casters swivel (as opposed to having casters at one end not swivel) make it hard to steer?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Originally Posted by jpump5Does having all four casters swivel (as opposed to having casters at one end not swivel) make it hard to steer?
Reply:Nice cart man!
Reply:I like it.  A lift kit and mudders and it'll be ready to go anywhere. Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Originally Posted by Leadhead1911I like it.  A lift kit and mudders and it'll be ready to go anywhere.
Reply:Great looking cart.   I like the way you improvised and was out very little cash.  That little jewel should last you a long time.
Reply:Originally Posted by swampwelder13I no it flipped over with all 4 swivels. So i welded the ones under the O/A solid.
Reply:Had some free time after I rolled out of bed this morning before we left to the beach house for the weekend. So I said what the hell ill finish something I started. So i welded a handle at the base and some pipe for the leads. Little bit of rustoleoum. And BAM shes done. Ready to be modified multiple times in the foreseeable future
Reply:13 wheel all terrain tool cart"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2026-1-1 07:47 , Processed in 0.100918 second(s), 18 queries .
