Repurposeing an old fence
发表于 2021-8-31 22:23:31 | 显示全部楼层 |阅读模式
Spent yesterday chopping down this fence and making it fit. It's in a terrifying neighborhood that's being gentrified. It keeps crack heads from sitting on that block wall and drinking/tossing bottles at the cars in the car lot. Glad I was packing, had a bunch of people come up and ask for money while I was working.  Chopped off about 10 inches on the bottom and attached it to a peace of 3/8 by 3" and attached it to those postes.
Reply:Good job.
Reply:Originally Posted by darlingtonfarm It's in a terrifying neighborhood ... Glad I was packing, had a bunch of people come up and ask for money while I was working.
Reply:Cut those loops off. Leave the spikes open.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Nice job, looks good!Real welders know how to penetrate!(Equipment)Whatever can be used to beat my opponent into submission!
Reply:How's the new welding bed working for you? Looks like it's set up nice!Real welders know how to penetrate!(Equipment)Whatever can be used to beat my opponent into submission!
Reply:Were you aware someone painted your Lincoln John Deere green while you weren't looking??Lincoln WeldanPower AC/DCSmith Oxy/Propane SetupVarious cheap - quality tools..  ;-)
Reply:Not only that look how far away he was from his tools ,must not have been all that bad of an area,I knew a guy had his welder stolen while welding ,someone hooked it up and drove off ,yanked the stinger out of his hand .
Reply:Originally Posted by gxbxcNot only that look how far away he was from his tools ,must not have been all that bad of an area,I knew a guy had his welder stolen while welding ,someone hooked it up and drove off ,yanked the stinger out of his hand .
Reply:Having the welder stolen while useing it is pretty crazy. Can totally see that happening, amazing what people will steel in that area. The building next door was broken into by knocking a hole in the block wall since the doors were all steel reinforced. Yep some one painted it green when I was haveing lunch..... I get a lot of love/hate from the farmers around here depending in there deere or ih. I'm loveing the bed, so much more useful than a pickup. I set 4 hitch receivers into it so I can have all kinds of crap hanging off it. Picked up some metal today to build a Hoosier pole that fits where the forward rack mounts. Been meaning to make a grill that mounts in one too.  Last edited by darlingtonfarm; 08-29-2014 at 08:46 PM.
Reply:The receiver idea is cool! I had problems with my pipe bender staying mounted to the floor, welded an old Reese hitch to it and stuck it on the back of the truck! Problem solved!!! And now it's portable!!! LolReal welders know how to penetrate!(Equipment)Whatever can be used to beat my opponent into submission!
Reply:Nice job.I hear you re the neighbourhood. Years ago a company I worked with were putting security screens over the bottom floor of a new school that had just opened. Meanwhile the animals were on the next floor up twisting off the coathangers, you know the kind that are made completely around the rod, and trying to spear us with them. We had to lock our torch in the truck whenever we we out of sight .....Mike
Reply:Nice job see Indiana plates where are you located?
Reply:thanks, I'm by Crawfordsville. It's about an hour north west of Indy on 65
Reply:Back down in that same area today. Building a quick ac cage. Like doing these take about 2-3 hours and make a couple hundred off them
Reply:Be careful blocking the disconnect. If the domicile is not finished, this will be a code violation. Like your work and love the fencing project. RegardsDave
Reply:Thanks, dident think of that, they padlocked the disconnect any way. Will keep that in mind for the next one.
GMT+8, 2026-1-1 07:47 , Processed in 0.071951 second(s), 18 queries .
