stainless pickle
发表于 2021-8-31 22:23:25 | 显示全部楼层 |阅读模式
I did a search, and couldn't find much here. Some things on the net about nitric acid, and hcl. not something you want to mix up at home I would guess. but maybe some of you have some ideas on this. I can't get to the welds on the inside of a small piece. thanks.
Reply:You trying to weld Vlassic Pickles?  Welding steel isnt good enough for you huh?  Gotta move on to the exotics?ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:www.weldingsupply.com sells a pickling paste good for 304/308 stainless steels.  It's not quite strong enough for 316.  It's under the cleaners and degreasers section.
Reply:Why are you trying to mess with aqua regia?  Have a pesky layer of gold inside that piece that you want to dissolve out?And you are right, messing around with aqua regia at home would NOT be a safe or prudent thing to do.More seriously, what are you trying to do?  Your statement about pickling stainless and some welds on the inside don't really tell us what you trying to do.  Clean it before or after welding?  Passivate the stainless after welding?  What?
Reply:Picking usually reffers to passivation and heat tint removal.
Reply:yes after the weld, in the places you can't get to with the abrasives. I don't have a reasonable sand blaster.
Reply:actually I live quite close to a vlasic pickle plant. But I don't think they want me to put my stainless in the pot.
Reply:Claussen pickles are better.
Reply:http://www.arcalchem.com/ has a line of pickling pastes and solutions.
Reply:Hi - new guy here.  I did a search to try to find some answers (no, really, I did!) but didn't really find what I was looking for.  Thought this might be an appropriate thread to put my questions under, as they have to do with pickling.I just recently picked up oxy/acetylene welding for the first time in a couple of decades.  But I have some projects that I think brazing would work better for.  In reading about brazing I came to the last step of pickling.  I'm having trouble figuring out what sort of container to use for pickling my brazes.  Just wanted to see what sort of containers you home/garage brazers are using to pickle your stuff in.  Based on this, it looks like a 50% solution of HCl is what my pickle solution will be - just need to find a large enough container to soak stuff in:  http://www.lucasmilhaupt.com/en-US/b...olutionschart/Side question - how necessary is pickling?  Can I get away without pickling?  I'll be brazing mild steel (maybe stainless at some point), and then painting it.  Mostly doing sculptural work, rather than structural/mechanical.
Reply:Welding/Fab Pics: www.UtahWeld.com
Reply:I pickle my braze sculpture in battery acid (35% H2S04). I use glass containers, either jars or flat casserole pans. I store it in HDPE plastic jugs, I bet you could use those too. Just cut the top off a laundry detergent jug or something. The reason I acid soak is to help remove the flux. I do heat/quench cycles first which crack off much of the "glass", then I soak in acid. After the acid soak (usually overnight), the flux comes off much easier, it usually becomes very brittle.
Reply:Originally Posted by MikeGyver
Reply:Yes yes, i know. I try to be helpful on this forum, but sometimes buckets-o-pickles really are just the best answer. just sayin...Welding/Fab Pics: www.UtahWeld.com
Reply:SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Thanks for the suggestions, DeuceTrinal!
Reply:I use Wonder Gel by www.bradfordderustit.com works great on 304-316AWS 17.1, D1.1 and ASME IX (GTAW)Miller Syncrowave 350LX, Maxstar 150sth, Maxstar 200DX and  Millermatic 252 w/ Spoolmatic 30aMiller buzz box with Lincolin TombstoneThermal Dynamics Cutmaster 38
GMT+8, 2026-1-1 07:39 , Processed in 0.080126 second(s), 18 queries .
