Mig thin plate. Smaller globular droplets.
发表于 2021-8-31 22:23:23 | 显示全部楼层 |阅读模式
For thin aluminum  plate, my welds are globular. In globular, the droplet grows and then falls into the weld pool. Any way to make the droplet size smaller.  I don't think that using different wires (0.8 or 1.0) will make any difference,  reasoning is that until the drop is large enough, it won't drop so will not make much difference.It will however, in spray mode. (I think) So can I spray with 0.8 wire and 2 mm plate ?If not, there are some 0.4 mm wires used for laser welding and was wondering if it was worth a try.(I assume 0.8 or 0.6 will spray at a lower power than 1.0 )The reason I asking is, here in New Zealand, it hard to get anything less than 0.9 mm so I have to import it. Best to ask first.Cheers Wallace
GMT+8, 2026-1-1 07:47 , Processed in 0.083934 second(s), 18 queries .
