WTB: early 1940's Shorthood exciter cover and idler
发表于 2021-8-31 22:23:22 | 显示全部楼层 |阅读模式
I've been wanting to get two Shorthood Lincolns to fix up and found one out of two, bought a 1942 model with a Hercules IXB5 that needs a few parts.1. Original type exciter cover with four holes on the bottom half, a standard one will work if I can't locate the original type that's no biggie.2. I know this will be a shot in the dark, a complete vacuum idler assembly and linkage rod that goes from the idler to the carburetor. Let me know what you have!RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
Reply:You might have some luck posting this on the aws forum also.
Reply:Thanks robphillips00, I did just that.I also need a manifold for the Hercules IXB-5 engine, the original one is ate up with rust. RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
GMT+8, 2026-1-1 07:47 , Processed in 0.115672 second(s), 18 queries .
