Miller 375 air pressure
发表于 2021-8-31 22:23:19 | 显示全部楼层 |阅读模式
Tell me about the air pressure on a Miller Spectrum 375 Cutmate.  It says "60 psi" on the control panel, with a range in green lines.  But when I set it in the range the light on the face for pressure lights up and the machine doesnt work.  If I put it up to 70 or 80 psi it works.  Whats the deal here?
Reply:Does the spectrum 375 have a built in air pressure regulator?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:its is built in, but manual...the xtremes are auto.
Reply:Maybe your pressure drops too much when you pull the trigger?My name's not Jim....
Reply:Is this a new unit,  I purchased one this past spring and had the same problem  had to go back under warranty.  Apparently a cannon type plug inside came undone in shipment  works fine now.
Reply:No, it is an older unit.  Also doesnt cut as well as it use too, tip looks good
Reply:Also noticed that when I hook up the air to the plasma cutter that it sounds like it is leaking inside the cover...
GMT+8, 2026-1-1 07:48 , Processed in 0.102697 second(s), 18 queries .
