my latest craiglist buy...
发表于 2021-8-31 22:23:18 | 显示全部楼层 |阅读模式
"new"...to me anyway.  Rockwell Porta-Band with standModel 725Hi: 246 sfpmLo: 195 sfpm$50  [url=]
[img][/img]
[/url] (direct link in case that didn't work...I'll figure this out sooner or later.) http://i1094.photobucket.com/albums/...A3NjAuanBn.jpgLincoln Ranger 250gxtLN-25Victor OA cutting torchMilwaukee mag-drillMilwaukee 6370-21 metal saw
Reply:Man they just don't make tools like that anymore, good scoreTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:NICE find on the saw.  REALLY nice find on the stand!Here's your obligatory "you suck"!
Reply:I couldn't believe it when I read the ad & saw the pics...it had already been listed for a day.  It was at a local high school.  The gentleman that sold it to me said that he'd been working there for 17 years...it was there when he got there. He said they used it for the first couple years he was there & it sat in a corner ever since.  The vise on the stand has been modified and the legs need a little work...but I couldn't be happier. My wife doesnt appreciate quite how awesome it is Lincoln Ranger 250gxtLN-25Victor OA cutting torchMilwaukee mag-drillMilwaukee 6370-21 metal saw
Reply:You better be grinning there Matt!  You just hit the lottery at $50.  Got the winning Power Ball numbers handy?RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:Ok guys.  I'm having some trouble with this saw.  The blade keeps coming off.  I tried switching the rubber-pulley tires around...every which way...no luck.  I'm not sure what else to mess with.  Parts are available...but damned if I know what to adjust/replace.  Any advice? http://www.ereplacementparts.com/por...2109_1853.html [url=]
[img][/img]
[/url]Lincoln Ranger 250gxtLN-25Victor OA cutting torchMilwaukee mag-drillMilwaukee 6370-21 metal saw
Reply:Try the bearings on the wheels. Fig.#12We have a Hy-Mech saw that was given new tires, torqued, tweaked and fussed over with no improvement. Last ditch attempt, put new bearings on wheels, and fixed it. It had too little movement to perceive, normally, but putting a dial indicator on the lash caught the movement. As soon as it was tight the wheel would drive the blade right off.  Might be similar in your case. Good luck, and sweet score.
Reply:I can't quite see the blade guides, but Milwaukees spit blades when the guide roller bearings wear.
Reply:Originally Posted by WelderMattMy wife doesnt appreciate quite how awesome it is
Reply:Originally Posted by papaharley03 Edited I think she has learned not to question my tool expenditures anymore.
Reply:Ok... I'm going to order two bearings, #12.  Anything other parts yall think I should order while I'm at it?Lincoln Ranger 250gxtLN-25Victor OA cutting torchMilwaukee mag-drillMilwaukee 6370-21 metal saw
Reply:Check the condition of those rubber tires, you may want to grab a pair if they are showing wear.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:They dont seem too bad...but..may as well put new ones on..eh?.  I'll order two of those also.  A friend mentioned that they're might be an adjustment to effect the pitch on the drive wheel.  Anybody know if that's true?  I downloaded the manual...but it was very vague.Lincoln Ranger 250gxtLN-25Victor OA cutting torchMilwaukee mag-drillMilwaukee 6370-21 metal saw
Reply:Originally Posted by WelderMatt..A friend mentioned that they're might be an adjustment to effect the pitch on the drive wheel.  Anybody know if that's true?  I downloaded the manual...but it was very vague.
GMT+8, 2026-1-1 07:39 , Processed in 0.103093 second(s), 18 queries .
