pipe beveler
发表于 2021-8-31 22:23:16 | 显示全部楼层 |阅读模式
Fresh from finishing up a toolpost grinder fixture and a torch circle cutter, I think I am up for my next fixture. If you have seen a Mathey Dearman manual pipe beveler they are good, and I am about ready to drop a dime on one, then I got thinking could I build one?????Gears and handle no sweat, saddle same, but the circular gear????http://www.matheydearman.com/product...e-manual.shtmlAny ideas?I don't have a rotary table so cutting the rack is not an option...maybe would need a favor which I don't want to use.I only want a manual machine.Last edited by fredschrom; 12-26-2011 at 08:43 PM.Reason: add link
Reply:Flywheel ring gears/flex plates and starter gears are the obvious inspiration for that setup, and starter Bendixes come with shafts.
Reply:I agree with farmall, the flywheel gear would be the place to get that.  I think I would have to do the same thing, since my dividing head wouldn't swing 8"
Reply:Sweet !!
Reply:if you dont do much pipe then they are kind of useless for anything else.    I have two of them that i bought over the years because they were cheep at auction.    I haven't used them once.If you dont do much pipe welding then they are just a cool paper weight that sits in my tool roomVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Flywheel..?...?..*....*.....*....Brilliant, I hate welding cast but I need to stew on that idea, there are more than 1 ways to skin the cat and the right flywheel, and exchaning sleeves. Hmm.Need to ponder that but an light bulb just went on.Thanks
Reply:fredschrom, maybe think in terms of flex-plate used on automatic transmissions, these are steel and not cast iron. I believe that is where dualie was coming from. Best regards, Allanaevald
GMT+8, 2026-1-1 07:31 , Processed in 0.101264 second(s), 18 queries .
