Pipe Merge Positioning Clamp?
发表于 2021-8-31 22:23:16 | 显示全部楼层 |阅读模式
I'm trying to TIG Weld merge a 2 inch stainless steel exhaust pipe into a 3 inch SS pipe at a 30 degree angle.  What do you folks recommend for clamping the two pipes together (with adjustable angle option) so I can do this job once...and only once ?
Reply:No such clamp exist, tack in place, check again half way through welding, finish it up.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:tack it in 4 -6 different spots put it on a bench and weld ( you got to do that anyhow to cap and purge it )Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
GMT+8, 2026-1-1 07:47 , Processed in 0.106175 second(s), 18 queries .
