Sae 300
发表于 2021-8-31 22:23:14 | 显示全部楼层 |阅读模式
Hi, I'm looking at a 1958 model Lincoln SAE300. I cant find any info on how well this machine will weld on lower amp settings. If I buy it this will be my only welder for a wile and I would like to be able to use 3/32 rod for the small stuff if need be. Any ideas?
Reply:Welcome to WeldingWeb, ZachRidesRed  I think the machine will tune down surprisingly well.Lincoln's SAE has one of the most refined controls ever built on a welder.Especially machines with the dual continuous control, rather than the stepped coarse switch, but either one is great at low currents.What power plant, Continental six?Good LuckLast edited by denrep; 04-28-2009 at 12:48 AM.
Reply:Yes it has the Continental six, it has been sitting for the last four years and needs some work but I can hand crank it and it still feels like it has good compression.I should be picking it up this after noon
Reply:I think you'll be pleased with it. We're anxious to hear more about the 300 and maybe even have a look.There are a lot of Lincoln engine-drive fans (enthusiasts) not radiator fans. Good Luck
Reply:I have a 1978 SAE 300.  Welds great with 3/32 !!  Mine has the f 227 inline 6 Continental.  If you want a smoother power source, you'll have to get the 3 phase electric version of the SAE 300.  The L Head 6 cylinder is a very smooth runner coupled with one of the best welding generators ever made.
Reply:Thanks for the help guys, I brought it home about an hour ago. I will try to post some pictures before the week end
Reply:I worked on getting the old girl running this weekend... I pored a little oil in each cylinder a couple of days before starting in on it. I cleaned out the carb and points. checked the coolant and oil, then blew all the dust off.The next step I put in some fresh gas with led additive (do you have any idea how hard that stuff is to find anymore?) hooked it up to a battery and it fired right up  ran like a champ.Now I need to hook the governor back up (the connecting rod fell off on start up) and I need to get the auto idler to work. Attached Images
Reply:Sounds good.Looks good too!Thanks for the pics.Next time, we get to see the mill!  Good Luck
Reply:Nice pics, I just finished going through my '63 sae 300 this weekend. Eventually I want to move all the controls to the front, but I guess your never really done working on em2011 Dodge 3500 diesel duallyLincoln SA-200Lincoln SAE-300LN-25'sLincoln Idealarc R3RMiller Trailblazer 302
GMT+8, 2026-1-1 13:19 , Processed in 0.128571 second(s), 18 queries .
