how many amps
发表于 2021-8-31 22:23:14 | 显示全部楼层 |阅读模式
im poping the breaker on a 20 amp circuit with a lincoln 140 after about a 8 to 10 second bead. how many amps do i need. and if i were to buy a generator what kind can i get that would work
Reply:30 should do it.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I would think that breaker is fine...What else is using that circuit?  How many amps draw does the machine manual (or tag) say it requires?  Is this just at full power, or all settings?  Are you using an extension cord (if so, how long, and what gauge wire)?  Tell us more!"Good Enough Never Is"MIller AC/DC  ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act  outfitTons of "stuff", all treasures to me!
Reply:it says imput current @ rated output 20Amps. imput power 120/1/60nothing else on circuit i think and its at full machine power but it was tripping the same at 75% power. was welding a metal rod to a flat piece. putting wheels on a engine houst. my old house never tripped a circuit so i never paid attention
Reply:you night need to replace breaker maybe worn out  or just a bad breaker but from your other post you say it s in the gargae it could be a gfi breaker they are known to trip easy
Reply:they are gfi in garage i did not think that the laundry room would be though was using a ridgid 10-3 cord
Reply:What welding wire and what setting on the Lincoln?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Lincoln Power Mig 140's require a 30 amp breaker
GMT+8, 2026-1-1 13:08 , Processed in 0.074928 second(s), 18 queries .
