I was trying to find the anwser thru the search and didnt find quite the response I was looking for. So whats the big difference in these two machines? I was at home depot and I saw that the 175 was on sale with almost $100 off. Is the 180 that much better that you would pass up on the 175 deal? I would only use the mig really for frame work so what would you guys do.Thanks, Slim
Reply:175 is the previous generation:Not Spool Gun readyDoes not have the Diamond Core ChokeEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:So is it worth the extra $110
Reply:Originally Posted by slimneverdiesSo is it worth the extra $110
Reply:Originally Posted by DanIf the 180 truly has the diamond core choke design, I say yes.
Reply:Originally Posted by Broccoli1According to Lincoln all of the new machines have it-
Reply:I doubt that I go up to 3/8 on anything that I weld. Im mostly interested in a machine to weld up my truck frame. Im a weekend welder. So should I go for the 180hd?
Reply:If Dan says it is worth the extra 100 then get the 180HD.I like it over the 175 since it will accept the Spool Gun iffin' ya wanna add that later.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1If Dan says it is worth the extra 100 then get the 180HD.I like it over the 175 since it will accept the Spool Gun iffin' ya wanna add that later.
Reply:Please don't mess with the Home Depot junk.. A local Lincoln dealer may be a little more expensive, but if you're going to buy a welder, why not do it right. Lincoln actually makes those machines specially for Home Depot and Lowes and they are not the same machines that local stores sell. They are cheaper built and do not have the same features. Lincoln may have a 3 year warranty on the machines, but how much is Home Depot really going to do for you? If you purchase these machines through a real Lincoln dealer, they will help you set the machine up the right way and if you do have any problems with it, they can assist you a lot faster and more efficiently than Lowes or Home Depot.
Reply:Originally Posted by lincolnwelderboyPlease don't mess with the Home Depot junk.. A local Lincoln dealer may be a little more expensive, but if you're going to buy a welder, why not do it right. Lincoln actually makes those machines specially for Home Depot and Lowes and they are not the same machines that local stores sell. They are cheaper built and do not have the same features. Lincoln may have a 3 year warranty on the machines, but how much is Home Depot really going to do for you? If you purchase these machines through a real Lincoln dealer, they will help you set the machine up the right way and if you do have any problems with it, they can assist you a lot faster and more efficiently than Lowes or Home Depot.
Reply:What info are you trying to tell me is false?
Reply:Originally Posted by lincolnwelderboy Lincoln actually makes those machines specially for Home Depot and Lowes and they are not the same machines that local stores sell. They are cheaper built and do not have the same features.
Reply:LWS don't even sell SP's anymore. The HD models are built for Home Depot/Lowes ONLY. LWS can't even purchase them without going through Home Depot/Lowes. They do not have the aluminum drive system and are still using the old style guide tubes, whereas the Power Migs are using a backplate that does not get blocked up with dirt/debris and stop the wire up and cause problems. When problems occur and warranty assistance is needed, Home Depot and Lowes have actually told people to go to LWS and receive assistance. AND, if any parts are needed, it can be very difficult to get them and most of the time are not even in stock.
Reply:Much better answer.I still don't think they are junk though.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by lincolnwelderboyAND, if any parts are needed, it can be very difficult to get them and most of the time are not even in stock. |
