just got a 100hd and i have a quick question
发表于 2021-8-31 22:23:14 | 显示全部楼层 |阅读模式
whats the thickest gauge flux core i can use on it without having to swap to a bigger feeder tube
Reply:If it's like my 175hd, the answer to your question is stamped on the end of your liner.If you pull out the gun you may be able to read it.I would guess 0.035, but that's just a guess.------------------------------Lincoln 175HDLincoln AC/DC225Smith O/A
Reply:Welcome to the forum touchmyself  (Man! Where do you guys come up with some of these user names?!).If you don't already have it, 'touch' the appropriate unit manual here http://www.mylincolnelectric.com/Cat...ualsearch.aspx and it'll probably answer alot of your questions and get you on a good headstart running that 100HD.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 09:34 , Processed in 0.083711 second(s), 18 queries .
