PRO-cut55 safety shut off?
发表于 2021-8-31 22:23:13 | 显示全部楼层 |阅读模式
Hello,  I have a lincoln pro-cut 55 that I have owned for 6-7 years.  Always worked until this one shop I'm in that has 248 volts coming into the shop.  When attempting to use it it sparks up for a split second and then all the warning lights come on and it wont do anything else.  Thought it could be the machine, brought it to where I used it last without changing anything and it works fine.  That shop had 240 at the plug.  Any thoughts?  My other inverter plasma works at thr 248!  Could it just be a safety shut off in the lincoln?Thanks.
Reply:call the manufacture...lincoln tech support
Reply:Yes they have over voltage protectionCheers
Reply:thanks for the info, I will have to call lincoln and get the specs.
Reply:Do you have good consumables in the torch?  & tight? Anything loose?.
GMT+8, 2026-1-1 11:19 , Processed in 0.109198 second(s), 18 queries .
