lincoln power mig 255c no arc
发表于 2021-8-31 22:23:12 | 显示全部楼层 |阅读模式
Help I cannot seem to figure out why.  Checked seems to have power everywhere.  I thought the ground maybe but no.  I was wondering if anyone was on who could help!!!  I can feed the wire through and have checked all wires. Checked the manual.  Any other suggestions???
Reply:I would start at the gun trigger. and where the trigger wires go into the machine.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Found it, it was a bolt that was loose had corroded and it was blk around it. Clean it up and it seems to work now. Must be part of the grounding. I'll hopefully get my new project done now. Thanks for the answer.
GMT+8, 2026-1-1 09:26 , Processed in 0.075587 second(s), 18 queries .
