restoring linclon weldan power 225
发表于 2021-8-31 22:23:12 | 显示全部楼层 |阅读模式
Iam trying to repair an old weldan power the problem i am having is that it will strike an arc but willnot weld the generator works well i have tried adjusting rpms with no sucess.the governor seems to let the rpm drop alittle but not a lot
Reply:Before we go any further agfab, do you know the unit code# and have the manual for it to refer to all the required operational procedures?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:i do have all the codes the only manual that i have is one i downloaded from the linclon web site not to much info
Reply:I should have asked - what is the unit code#?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:the code #is 5229serial#516779ac225/5-as these are all the #on the machine
Reply:agfab,I have a Weldan 225 with a briggs&stratton,it started doing almost the same thing.I rebuilt the carb changed the filter,to findout that it was rust in the gas tank.I pulled the tank got some tank sealer from a motorcycle shop sealed it and end of problum,my not be but worth a look.
GMT+8, 2026-1-1 09:26 , Processed in 0.099698 second(s), 18 queries .
