New TIG cart build
发表于 2021-8-31 22:23:11 | 显示全部楼层 |阅读模式
I recently purchased a new TIG welder and a Coolmate 3 and of course needed a place to put them. Instead of modifying a HF cart I thought I could use the practice building one from scratch.Here are a few pics from about midway through the build. Attached ImagesLast edited by Turbinecopter; 08-26-2014 at 07:17 PM.
Reply:Here are a few more with a bit more work done.Last edited by Turbinecopter; 08-26-2014 at 07:13 PM.
Reply:The local powder coating shop did a great job making my cart look a little less home made. I added a solid state relay inside of the 110 volt outlet box that is switch by the output on the welder. It turns on the cooler so I don't forget
Reply:Shore is purty. Powder coating will pay off.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:A couple with the machines in placeLast edited by Turbinecopter; 08-26-2014 at 07:37 PM.
Reply:Originally Posted by GravelShore is purty. Powder coating will pay off.
Reply:Really nice. How would you consider the durability compared to paint?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Thanks. I have been powder coating my projects for years. It is so much more durable than regular paint. The drawback is that if you want to change something you will have to blast it all off and have it redone. At least with paint you can reshoot an area.
Reply:I thought you could just spray over the top with powder, no?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:I don't think you can re-bake over the top of previously done powder coating.
Reply:You can but it tends to screw up the old finish. Sometimes even weakening the bond with the metal.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by TurbinecopterI don't think you can re-bake over the top of previously done powder coating.
Reply:Thanks. That's great to know. Any pics of something you have had recoated?
Reply:The attention to detail really shines. Good job!
Reply:Originally Posted by Gambleyes you can. i just got into this and I did a few things that I had a few spots that  I missed, sprayed and rebaked and it was fine.
Reply:Very nice work!
Reply:Great job on the cart - very nice. Originally Posted by Robert HallReally nice. How would you consider the durability compared to paint?
Reply:Excellent build.  Love the design.
Reply:I added a solid state relay inside of the 110 volt outlet box that is switch by the output on the welder. It turns on the cooler so I don't forget
Reply:Originally Posted by HeartdocReally nice cart.  Could you explain exactly how you wired the relay? How does the output of the welder connect to the relay?
Reply:That cart looks like mine a little.  There is a 220V 30A feed to the cart that powers all three units.  I also break the both sides of the phase to separate 110V outlets on the cart.  There is an line for air for the plasma cuter and an extra hose so I can use air tools.  There is one ground for all three units with a quick connect for each unit.Top left 25ft air out line for air tools.  Top right is super flex TIG torch.  Bottom left is 25ft air in line for plasma cutter and air out line.  Bottom right Plasma cuter torch.From top to bottom, 210A TIG, 60A plasma, 180A MIGTop left is the super flex ground cable.  Top right is 25ft 110V power.  Bottom left is the flex head MIG gun.  Bottom right 220V 30A power in for the cartI also power coated everything.  Including the outlets.  We must think alike.This the drawing I sent to get the metal bent.Last edited by Judgeless; 09-02-2014 at 04:37 PM.
GMT+8, 2026-1-1 11:22 , Processed in 0.071334 second(s), 18 queries .
