Conveyor hopper lining
发表于 2021-8-31 22:23:09 | 显示全部楼层 |阅读模式
Few pics of a hopper I lined few weeks back.All 3/8"Hardox500.Welded with NR-232 .068dia. Attached Images
Reply:Oh I want the little crawler that is under it!!!
Reply:Best way I found to stop hopper wear is weld in angle iron so it fills w/ rock and bolt 3/8" or I/2" flat, that's wider than the angle by an inch, to the angle so it takes the impact. When it wears down to the angle, replace. This may take 2 or 3 steps up the hopper depending on the width of the stream falling in the hopper and other variables.                                                         MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2026-1-1 11:20 , Processed in 0.108277 second(s), 18 queries .
