Watch "Sand separator" on YouTube
发表于 2021-8-31 22:23:08 | 显示全部楼层 |阅读模式
Sand separator:  a short video of that sand separator
Reply:I was supposed to load this in "what you welded today" but too much beer.
Reply:I was hoping to see it in action. I can't find any others on YouTube except small homeowner units that I guess are used for well water. Did you use spray transfer on that project? The whole build looks great!
Reply:Kobleco DW316lp fluxcore dualsheild its the best stuff ever, we used carbon flanges clad with 316l plate and the gasket surface was machined out and built back up with 309 then 316.
Reply:colindstarkGreat work . . .It appears to be: a 'Heaviest' sand-separator.Can you extend a whiff of its actual service: and what cover gas do you use with Kobleco DW316lp?Opus
Reply:As far as i know its used to get the sand out of the black liquor in a papermill see this wiki page for a better explanation http://en.wikipedia.org/wiki/Black_liquorFor shielding gas we use 75/25 argon/co2.
GMT+8, 2026-1-1 09:26 , Processed in 0.072036 second(s), 18 queries .
