Esab 81T1-N1 Problems welding with this wire
发表于 2021-8-31 22:23:03 | 显示全部楼层 |阅读模式
Ok guys here is the deal at work we are running this wire,  lots of guys are having issues,  im primarily a stick and tig welder.  Basically we can get set up on a machine and get dialed in and this wire welds good,  now next thing we know we can go to another machine and have issues even though using the same settings.   All machines are new and calibrated...  Spatter issues seem to be the norm when this occurs.  We are required to return our wire at the end of shift to the tool room.   Im wondering if different wire tensions on these wire feeders could be causing feeding issues maybe ?  I dunnoAny help on this wire would be appreciated...Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
GMT+8, 2026-1-1 11:21 , Processed in 0.120937 second(s), 18 queries .
