查看: 13|回复: 0
miller bobcat not charging
发表于 2021-8-31 22:22:56 | 显示全部楼层 |阅读模式
i have a bobcat 225 and its not charging i have checked the stator not grounded new regulator when its running the 2 out side wires 1 has 9.1 the other has 0 what would be the resistence between the 2 outer wires any help would really be great thanks dale
Reply:Engine?What is the resistance across the two stator output leads?Sounds like there may be an open between the plug and windings on the 0V side which would show up as no continuity between the two putput leads.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane putput leads ?? that hilariousMiller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:its a onan p220 between the 2 leads is .5
Reply:Originally Posted by dumb as a stumpDuane putput leads ?? that hilarious
Reply:tore the fly wheel off keeped the meter on and wiggled the wires stayed the same .when i had it running and moved the regulator it would spark so there is juice coming from some where my old reg would not spark when i tried to ground it. magnets are all tite just a little bit of serface rust on the stator
Reply:It's imperative that the regulator be grounded to the air housing and air housing to engine for proper regulator operation.  There must also be a good battery connected as the regulator will "turn off" with no battery or any open in the battery power circuit.  A dead battery will be "seen" by the regulator as an open circuit preventing it from "turning on".MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:this chargeing system isnt like a car where you can take the battery cable off and it will still run ?miller trail blazer ,miller bluestar,licoln tig 300/300 ,lincoln buzz box ,lincoln hi freqency box, 2 super s32p suitcases ,miller matic mig, ln7,60 inch southbend lathe,craftman 110 mig, L TECH 250 HF, binzel push pull gun ,36 inch hendey lathe
Reply:Nope.If that's how you are testing it, you'll get a false "fail" every time.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:im going to put it back together today the stator should be ok when i fire it up the out side wires should read the same as the battery ? thanks for all your helpmiller trail blazer ,miller bluestar,licoln tig 300/300 ,lincoln buzz box ,lincoln hi freqency box, 2 super s32p suitcases ,miller matic mig, ln7,60 inch southbend lathe,craftman 110 mig, L TECH 250 HF, binzel push pull gun ,36 inch hendey lathe
Reply:Depending on which stator you're working with, the AC output across the outside leads at weld speed should be approximately:20A (Spec A) - 41VAC20A (Spec B and up)  -57VAC35A - 47VACDC output on the center lead to the battery circuit should be 13.6-14.7VDC (with a good, charged battery connected).Last edited by duaneb55; 12-30-2011 at 09:56 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:got it back together and is charging like it should thanks for all the help dalemiller trail blazer ,miller bluestar,licoln tig 300/300 ,lincoln buzz box ,lincoln hi freqency box, 2 super s32p suitcases ,miller matic mig, ln7,60 inch southbend lathe,craftman 110 mig, L TECH 250 HF, binzel push pull gun ,36 inch hendey lathe
GMT+8, 2026-1-1 15:12 , Processed in 0.124435 second(s), 18 queries .
