handheld grinder and getting straight cuts
发表于 2021-8-31 22:22:55 | 显示全部楼层 |阅读模式
any ideas on this? I cannot afford a metal chop saw at the moment and am not getting very straight cuts with the angle grinder. I was thinking to make a device where I can clamp down my metal (small angle or tube steel) that has a guide I can run my grinder along to get a straight cutany one done this , have any pics?
Reply:I've done the straight edge method before works ok if ya don't cut into your straight edge. Use the thin cutoff wheels, which I think is 0.45. I normally then just follow my line. some people scor the line first then cut,but ive never had much luck with that. I just go for it, letting the cutoff wheel sort get on plain like a boat in the water ,letting the wheel do the work.
Reply:I've used the straight edge "guide" in some cases, but normally just free hand it. After you do enough of this you get decent. They do make a replacement guard that will fit on a 4 1/2" grinder with a shoe similar to what is on a circular saw that you can ride against a fence. This works great with diamond wheels on tile and such, but not so good with abrasive blades that wear down as you cut..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Unless it's a very short cut, like your tubing and pipes you're talking about, I always score the cut first and then complete it.  I don't use guides.  Practice makes perfect - you have to be smooth and fluid, just like other processes that we deal with.What are you using to mark your material with?  If you want accurate hand cuts, you need to toss your soapstone somewhere that you won't find it and use something like a silver pencil or thin-tipped sharpie depending on the material.Finally, if you're not using a full face shield for this, you need to get one and wear safety glasses inside of it.  Then you won't be squinting so hard that you can't see the line you're trying to use.
Reply:guides are good as long as you are on them....its really easy to "walk" off of a single sided guidebobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:score it once, let the wheel pull the grinder along the material and concentrate on getting the score straight. After that the wheel will follow the score and your cut will com out straight. On pipe, having a way to roll the pipe along the wheel for the score helps a lot, square tube I lay out straight lines on all 4 sides and score around the tube then start my cut at a corner, cut 2 sides from the same corner flip it over and cut the other 2.
Reply:try this link its 25.00 from grizly    looks pretty slick        http://www.grizzly.com/products/4-1-...er-Stand/G8183 Attached ImagesLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:Fill out your user CP with your location. If you were close to me I'd give you a chop saw.
Reply:Originally Posted by heimbuckweldingtry this link its 25.00 from grizly    looks pretty slick        http://www.grizzly.com/products/4-1-...er-Stand/G8183
Reply:Originally Posted by bobjenkinsany ideas on this? I cannot afford a metal chop saw at the moment and am not getting very straight cuts with the angle grinder. I was thinking to make a device where I can clamp down my metal (small angle or tube steel) that has a guide I can run my grinder along to get a straight cutany one done this , have any pics?
Reply:I used a sidewinder skil saw for years, with just a 7 1/4" cutoff wheel.  Just wear protection for your ears, eyes, lungs and fingers.  Like anything, it takes practice to get precise.  I've seen guys who can cut a piece of tube with a sawzall and you'd swear they used a chop saw, the cut was so straight.  Go to HF and get a cheap chop saw.  You just have to work within the limits of the machine, not expecting 4 hp performance out of a 2 hp machine.  BTW, my Milwaukee super sawzall was made in Italy.  Just sayin', don't want to start that debate up again.Contrary to popular opinion, I do NOT have a pet turkey that craps molten steel.  It's a goose.
Reply:look at my post under homemade tools, I bult a toolpost grinder for my lathe, same principle you could make a grinder guide.
Reply:This was mentioned....and should work well with a straight-edgehttp://www.harborfreight.com/safety-...ers-45921.html
Reply:wow thanks for all the ggreat ideas and advice everyone! Seems there are quite a number of ways to do it. If I try anything ill post it
Reply:I've cut sheets before with an abrasive blade in a skill saw.  Just scrounge up an old all metal saw.  Mine was a free bee.My name's not Jim....
Reply:i was at harbor freight today and they had a 6" chop saw for 35.00 its cheap but would get ya buy till you could buy a 14"Lincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:You will find that "wood" saws have exactly the same motors and the same rpm as "metal cutoff" saws.So, saw benches, radial arm saws, sidewinder saws, and all the rest work fine for us.And in the smaller sizes, are pretty useless for any serious wood butchery and often go really cheap secondhand   **HINT**Cheers,  Tony._________________________________Transmig 310 + Argoshield LightOxy acetyleneOxy propanePrehistoric stick welder_________________________________
Reply:Make sure you have a clear line of sight on what you are cutting as well, it helps tremendously.Not sure if anyone said that yet...JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:Originally Posted by joebieMake sure you have a clear line of sight on what you are cutting as well, it helps tremendously.Not sure if anyone said that yet...
Reply:Originally Posted by walkerFill out your user CP with your location. If you were close to me I'd give you a chop saw.
Reply:Originally Posted by WarpspeedYou will find that "wood" saws have exactly the same motors and the same rpm as "metal cutoff" saws.So, saw benches, radial arm saws, sidewinder saws, and all the rest work fine for us.And in the smaller sizes, are pretty useless for any serious wood butchery and often go really cheap secondhand   **HINT**
Reply:Originally Posted by Ken SmithThis was mentioned....and should work well with a straight-edgehttp://www.harborfreight.com/safety-...ers-45921.html
Reply:$40 6" cutoff saw http://www.harborfreight.com/6-inch-...saw-41453.htmltackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Originally Posted by graniteguyShoot, now you can even get a laser guide that straps onto your tool.  It's cheep and available from several places and just takes a couple of minutes to attach and adjust.
Reply:Originally Posted by AwelderiamHow do you attach the 14" fiber blade in the smaller wood saw housings? Fiber saws are dirt cheap why ruin a wood cutting saw?Originally Posted by joebieKind of like a shark with a laser beam on it's head ;-)Sorry I couldn't resist the Austin Powers movie reference. LOLBut yeah, I may look into that as it sounds pretty handy.
Reply:I don't really have a suggestion as far as tools go. But my advice is to make sure you position yourself so as your comfortable as possible. I don't know your situation, surroundings, or skill level but I've seen many people struggling with a cut-off wheel because they're not holding their grinder properly or their work is not secured properly or sparks are flying back in their face etc. If it seems difficult your probably not doing it right.
Reply:you could live in ghetto neighborhoods where people get evicted all the time and score a free miter saw like I did a couple years ago. LOL..for once i actually listed to the wife and the neighbors across the street from where we lived got evicted and had a big pile of stuff sittin by the curb. among all the junk was a 10" ryobi miter saw and the wife said i should go grab it. I just figured it was some broken POS and was going to leave it there, glad I didnt because it works great and the price was right. I actually dont have a metal cutting blade on it yet, just havent had the need but since I just started welding i think that'll change soon. I usually use the angle grinder and a cutoff wheel but I cant cut a straight line to save my life so I cant help ya there.
Reply:If i have the time and it needs to be a tight fitup i do rough cuts with the angle grinder or portabandsaw and then dress it up with the disc sander.
Reply:http://www.harborfreight.com/safety-...ers-45921.htmlMay not be what you want, but this makes cutting on a flat sheet like cutting plywood with circular saw. Attached ImagesLast edited by TxDoc; 01-05-2012 at 03:45 PM.TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
GMT+8, 2026-1-1 09:26 , Processed in 0.096394 second(s), 18 queries .
