sa 200 code / sn#
发表于 2021-8-31 22:22:52 | 显示全部楼层 |阅读模式
found an old sa 200 but the face plate can't be read. is the sn and code located anywhere else on the machine?thanksdave
Reply:I think it was denrep that stated awhile back that the unit #s are stamped in the generator housing near the engine/generator split line.  Can't remember if he said which side though.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:The serial number isn't anywhere else, the code number should be stamped on the generator barrel at around 2 o'clock and may be covered by the paint.JTMcC.
Reply:Dave   If its a Canadian model there were no code #s issued             Felonhow about some pictures the guys can usually come pretty close by just seeing sameCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:here's some pics
Reply:with the faceplate shown(L51710) your codes would run #7243 to 8000 and your manual would be im276b for download from lincoln.the exact year i cant say            FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:I forget the model years ('70's something) but the octagon generator housing indicates the probability that it has aluminum windings - not that that's bad from a performance standpoint as I understand it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks for the help guysabout the code , what are ya'll calling the generator barrel? where it mates to the engine? ive looked on it around the 2 o' clock and found nothing, must be looking at the wrong place.dave
Reply:Originally Posted by Felonyass Monkwith the faceplate shown(L51710) your codes would run #7243 to 8000 and your manual would be im276b for download from lincoln.the exact year i cant say            Felon
Reply:Dave,Check with these folks. http://billswelderrepair.com/home.htmlIf they can't help you determine or find it no one can.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:From the pics I see:- The octagon generator from the years 1972 - 1992.- The electronic idler that came in May 1973 @ code 7275.- The welding lead connections were mounted the way yours are between 1973 and 1979Would you be able to lightly sand the code and serial to see if the numbers show up or was it not stamped?Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:I have 2 of them just like yours,I belive one of the guys told me on the starter side of the welder or you could say if it was your truck the passenger side,just pass where the octagon part of the generator is where it is smooth and you may have to lightly sand the area at about one oclock or so you should find the code #s I found them on both of mine.
Reply:Very similiar to my 1975 SA200 code # 7307
Reply:The barrel is the generator housing.The code number is there, but you'll have to look for it. They can be covered by the paint, but it's there.JTMcC.
Reply:Did you ever clean the paint and find the code?Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:no at work now for the next week, so it;ll be a little while before i get a chance.dave
GMT+8, 2026-1-1 09:34 , Processed in 0.082923 second(s), 18 queries .
