Aluminum Windings
发表于 2021-8-31 22:22:52 | 显示全部楼层 |阅读模式
How do you know if your machine has aluminum windings.Sorry for all the last minute questions but going to look at a 1970's SA 2001990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:if the generator housing is hexagonal then its aluminum windings. Unless someone has had the whole thing rewound with copper.My vintage equipment 1957 Lincoln sa 2001980's Lincoln 225 AC1952 F-2 ford truck1957 F-250 ford truck
Reply:Ok, I thank you for the reply. I had a appointment with the man and he called it off.I guess that hexagonal thing goes for the 250 also?1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:I believe its the same for the 250 also. The aluminum windings were bigger than the copper ones, so they had to make the generator housing bigger to fit them.My vintage equipment 1957 Lincoln sa 2001980's Lincoln 225 AC1952 F-2 ford truck1957 F-250 ford truck
GMT+8, 2026-1-1 09:34 , Processed in 0.434956 second(s), 18 queries .
