New 3200HD
发表于 2021-8-31 22:22:52 | 显示全部楼层 |阅读模式
Finally took the plunge into a wire welder.  Found this unit at HD on there closeout shelf for $295.  Now I have to learn to use it.  A few questions:  Any thing I can put on the wire to prevent rusting while not in use?  Any trick to welding slightly rusted metal?  I found it hard to strike an arc even on the highest setting.  What's the most economical source for shielding gas and the tanks?  I mainly want to weld mild steel and have heard using gas makes a much cleaner weld.  Any help will be greatly appreciated!Eric
Reply:Originally Posted by edjones72 Any trick to welding slightly rusted metal?
GMT+8, 2026-1-1 09:26 , Processed in 0.070664 second(s), 18 queries .
