Info on 1990 SA200
发表于 2021-8-31 22:22:51 | 显示全部楼层 |阅读模式
This machine has 1985 hr. looks pretty good, paint not real bad. The only thing I dont like is it has alum. windings. It welds good smooth arc, course I am use to miller Bobcats and Trailblazer. Tell me if this is normal it use 1qt oil every 100hr. oil looks real good. Small front seal and rear seal leak not even a drip just has a film.  You think this machine is worth 3000.00. Actually I am tradeing a Trailblazer with 10hr.on machine, I got this machine on a warranty,my old machine just quit.Oh this machine was built in Canada.1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:so it's 3 grand PLUS your 10hr Trailblazer. or straight up for your trailblazer? Sorry for being s-l-o-w, I just wanted to make sure I was reading your post correctly. I always say say when asked about price, "it's worth what someone is willing to pay". I know that doesn't help you.    If you're not crazy about the windings, hold out for a copper machine. Asfar as the windings go, people will argue that topic from now on. I've got a copper SA and like the way it performs, BUT with that said I've never used an aluminum machine. I'd love to have one to do alittle side by side testing.Hillbilly Fabworks
Reply:It's a trade,I figure it's worth 3000.00. They sell for 4045.00 but you know how it is when you drive it off the lot.1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Bump1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:me personally..... Well I would keep the trailblazer.  A trailblazer with 10 hrs on it in my opinion beats a machine with 1985hrs that you have no real idea on the history of it.  not to mention the warranty on your trailblazer and NO warranty on the SA...  Just my opinion, but I would not make that swap...I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:My only thought is these machines are still around and on the job after 40 years. I was kind of hoping this would be my last machine to buy even if I had to put a little in it. I dont know thats why I am asking thanks for the post.1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Well, it's not as simple as swapping welder for welder...  It depends on what you are going to be doing as well.  I recently bought an SA 200, but for what all I do I could not use it as a primary machine. One thing to consider is that the SA have NO AC auxillary power.  It's straight DC even out of the outlets.  So where as if you needed a generator like you can use your trailblazer for you will be out of luck with the SA200.  it also means the only tools you can power will be AC/DC tools.  if you are gonna be doing pipework where all you are gonna do is run stick and use grinders for the most part an SA is an Awesome machine, but in the repair side of things like I do I need the AC for tigging Aluminum, and I also use the CV output for a suitcase feeder.  And especially when the current goes out and I need to power the freezers etc in the house you won't have a problem like you will with an SA 200.  Just things to think about.   SA's have their place, but like I said earlier there is no way i would trade a trailblazer with 10 hrs and a warranty on it for a used SA with 2000 with none.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Yea I see your point, I have a 2006 Bobcat 225 that I will keep around it's been my back up welder and oniy has 500 hr. As far as a suitcase welder I wish I had one. I read on here somewhere that if you use a good brand name like Milwalkie or Dewalt you are ok just stay a way from vairable speed?1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Did I read on another forum, that you traded for it?Hillbilly Fabworks
Reply:Yes I traded my 302 TB for it.1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
GMT+8, 2026-1-1 09:26 , Processed in 0.075140 second(s), 18 queries .
