SA200 idleing problem
发表于 2021-8-31 22:22:50 | 显示全部楼层 |阅读模式
Just got this 200 running and runs real smooth but it idles to fast you can manualy move the idle arm back to the stop and it will idle down but when you let go of it it will go back up to a faster idle not to welding speed but just to fast of an idle.
Reply:Walk yourself though all the carburetor and idler adjustments and you should be able to correct whatever is out of wack.Don't know if you have the older vacuum or newer electric idler so here's the information for both.http://content.lincolnelectric.com//...r/im/IM179.pdfhttp://content.lincolnelectric.com//...im/IM179G1.pdfhttp://content.lincolnelectric.com//...r/im/IM277.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 09:26 , Processed in 0.099935 second(s), 18 queries .
