Watch "Home built tube bender" on YouTube
发表于 2021-8-31 22:22:46 | 显示全部楼层 |阅读模式
Home built tube bender:
Reply:Same one I built about 3yrs ago. Use a 1.75" die and made sleeves for 1.5" also. Except mine is stretched a little and powered by a coverted steering pump and a 4"x24" hydraulic cylinder. Makes 180deg bends in under 30secs with a whisper of noise and no physical effort!Airco Heliweld II AC/DC HomeMade Wire FeederLincoln 255PLincoln HD130Everlast PP804x8 CNC TableWelding helps me build my hobbies and takes up time on the side.
Reply:Pretty clever adaptation. Better wear hearing protectors, though.
Reply:Nice bender, what brand is your mill/lathe ?Miller 252 Mig w/Spool GunMiller Dynasty 350 TigMiller 225 AC-DC StickMiller Spectrum 875 PlasmaOxy/Acet.
Reply:where can I get plans and drawings for it?great job!
Reply:Yes I would like a set also. Nice design
Reply:Thanks guys! I believe if you search fof got trikes bender you can source them from ebay
Reply:Thanks will look that up
Reply:Missfire, My mill/lathe is a smithy granite 1324
Reply:That's awesome. It would be cooler if you share the plans for it.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:That would be nice.
Reply:Frank made the price of the plans very reasonable and asked buyers not to share.Would you like someone doing that to you?????DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:They do now!
Reply:After you buy the plans which gives you a discount on dies you'll realize that all the effort he put into them to make life easier that it is well worth the measly 20.00 he asks. I was asked to share mine when I bought them and I refused solely on the point of not ripping off the time he put into it to save others.Airco Heliweld II AC/DC HomeMade Wire FeederLincoln 255PLincoln HD130Everlast PP804x8 CNC TableWelding helps me build my hobbies and takes up time on the side.
Reply:exactlyDIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
GMT+8, 2026-1-1 09:26 , Processed in 0.107185 second(s), 18 queries .
