I think I got my money's worth out of this wheel today............... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:You can get another 1/8" off of that!!Buy American, or don't whine when you end up on the bread line.
Reply:I'd say you did! lolLincoln Electric, Power MIG 256Hypertherm Powermax 45 Miller Dynasty 280DXSmith O/A torchGenesis of a welding table
Reply:BTDT Never weld more in an HOUR than you can grind off in a DAY!!!
Reply:Your spoiled , I know less fortunate welders who would kill for a low use wheel like that, LOL. turn down that retainer nut in the lathe and you can get a couple more jobs out of that wheel. I worked for a shop when I started where the owner would pick up the 7018 stubs if they were over 2" long and start quoting values like 25 cents or a nickel, whatever.Last edited by kolot; 12-29-2012 at 10:22 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:I swept the garage six times today...... Full dustpan each time.......A couple were from under the band saw, but much was from the DeWalt.........10 hours..... Non stop cutting and metal prep...... Fun times!Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Holy cow, Fexal! You get them A LOT smaller than I do. The guard usually gets in my way long before that."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by FexalI swept the garage six times today...... Full dustpan each time.......!
Reply:I try to use all my grinding disks close to that point, unless the grinder starts vibrating bad, then in the trash they go. By the way, not to try to thread jack, but has anyone used KT industries grinding disks or cut off wheels? I used one of their grinding disks the other day to grind off about twenty small rivets. It wore out super fast. Didn't even come close to comparing to my Continental grinding disks. Their cut off wheels are even worse. I've had great luck with the Diablo line of disks and cut off wheels as well.-Pat
Reply:Originally Posted by SuperArcMan 10hrs of metal prep. Can't wait to see what you're making! About all that grinding dust.....
Reply:Originally Posted by SuperArc ... About all that grinding dust ... grinding "shrapnel" inside the garage and all over the tools ... I also wheel my chop saw out as well ...
Reply:Years ago i used to work for a company that wouldn't give you a new grinding disc without you taking the old one back to them, The Guy had a piece of wood with a hole, and if the disc didn't fit in the hole he made you use it until it did I think the practice stopped when the Director queried the amount of new Grinders we had to buy because everyone messed the thread of the grinder where it would mark the metal as your trying to push that tiny disc hoping that it would still grind.Totally idiotic, i think they got rid of this guy in the endLast edited by Gerry1964; 12-30-2012 at 07:41 AM.
Reply:Originally Posted by AMWelder89I'd like to know what he's making to
that's quite a bit of prep work. I hate cleaning up all that dust
-Pat
Reply:By the looks of that wheel, I'm guessing your neighbors must love you Fex.....
Reply:I keep a few of the smaller ones like that around for times you need a special position or spot you can not get with a larger wheel or need a small grind for something. Looks good man!!Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter Hobart 10,000 Welder-Generator Have a good day!!!
Reply:Nice! Keep the little wheel for a heat barrier while welding. I normally have some sort of stone around for when I have to rest my hand on the part I am welding.
Reply:I run my grinding wheels until they're wore down like that too. I try to get my money's worth too. Chad |
