查看: 2|回复: 0
pyramid post caps
发表于 2021-8-31 22:22:38 | 显示全部楼层 |阅读模式
made these out of .080" aluminum, 3003 H-14.  Sheared the blanks, then formed the two halves on the brake, and welded them together.  They will be painted gloss black.  They were quite a bit more fussy than I expected, but then I am no sheet metal expert. Attached Images
Reply:nice!
Reply:Nice, is this something you could make a die and press them out with a press?
Reply:Nice job. Outside corners like that on thin alum isn't easy..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nicely done Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Pyramids are 3 sided aren't they??...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Tell that to to the Pharaoh Cheops.   .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:no three side is a triangle !
GMT+8, 2026-1-1 09:26 , Processed in 0.104397 second(s), 18 queries .
