create realistic welding defects in carbon steel tubes
发表于 2021-8-31 22:22:26 | 显示全部楼层 |阅读模式
dear friends,        I would like to create realistic welding defects in carbon steel or alloy steel tubes for learning purpose. But i dont know how to do it. pls help me.
Reply:Get someone who has never welded before to weld on them...Rich
Reply:Just start welding.  Welcome.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:I have acouple of people at work who have perfected this lol. Na mostly weld dirty materials, use old consumables, use wrong machine settings ie to hot or cold, wrong arc length oh I could go on for daysSent from my C811 4G using TapatalkVantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:Study the welding fail thread and then weld exactly like that or just take the metal to Willie and let him do it, he's a professional.My "collection":Homemade Stick WelderVictor O/A TorchAC 225Ideal Arc 250HF 90 Amp Flux CoreHF Mig 170Solar 2020 Plasma CutterPower i-Mig 140EHarris O/A torchHF Dual Mig 131140STAlpha Tig 200x
Reply:Originally Posted by steelsurgeonGet someone who has never welded before to weld on them...Rich
Reply:Well, finally something I am qualified for!
Reply:call sean at yougizmoi.u.o.e. # 15queens, ny and sunny fla
Reply:1. mig w/out shielding gas.2. flux core wire with insanely high wfs/voltage3. stick welding w/ high moisture rod.4. dirty/oily/painted steel (can be combined w/ 1 & 2)5. low wfs/voltage for wire size.unfortunately, I've done 1,2,4,5. - it all turns out bad but a few look 'ok' until stressed, then it's time to break out the grinder/sandblaster/die grinder and re-weld. kinda suspect ramasethu may be trolling but I'll give him/her the benefit of the doubt.
Reply:How about Mr. Tig.  Wyatt or whatever the hell his name is.Miller Big 40GMiller HF-251 D High FreqVictor OA Lincoln 135 MigMK 3A CobramaticBridgeport J HeadCronatron OxylanceRadnor ACAG TorchWeldcraft TIG Torches1 blown knee and two 5 Gallon pails away from being a hero.
GMT+8, 2026-1-1 09:34 , Processed in 0.079871 second(s), 18 queries .
