53' shorthood having welding issues
发表于 2021-8-31 22:22:22 | 显示全部楼层 |阅读模式
I bought the machine a few months ago and finally got around to burnin some 5p downhill and uphill with it yesterday but wasn't very impressed. It seemed to me like it will fire up cold and if I long arc it the slightest it would die out. Even when it started to cooperate for a few seconds it would still die out. I had way too many stops n starts the bead didn't look slick like it should. It was aggravating me Bc it made it seem like I couldn't weld lol and it wasn't Bc the machine was too cold I messed around with it for a good while but then I fired up my lincoln ranger and had no trouble at all out of it. I will add that the shorthood is practically like brand new the motor has been bored with all new internals and the generator has all new brushes maybe it needs to be broke in?? I was just disappointed Bc everyone says the old lincoln gas machines weld like a dream. If anyone has any advice I would appreciate it
Reply:Originally Posted by JJamesW If anyone has any advice I would appreciate it
Reply:Knowing what your settings were might help to point to any setup issues.Knowing what the engine high idle RPMs are and OCV might help point to any machine tune-up issues.Insaneride makes a good check suggestion.  Using a voltmeter set to DC, check OCV between the (+) and (-) weld output posts with the red lead on the (+) post and black on the (-).  A "-" sign in front of the voltage figure indicates the unit's polarity is backwards and needs to re-flashed to correct it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks for the advice fellas I'm gonna get a voltmeter and check it out. What gear and voltage do I need to put the machine on to check the ocv's. It only has 4 gears not 5 like the later sa 200s. I think it's set too high anyways because the machine is idled up high it sounds. Sorry for all the questions but this is my first sa 200 and need to get all the bugs worked out of it.
GMT+8, 2026-1-1 09:34 , Processed in 0.104968 second(s), 18 queries .
