4943 Alloy Filler?
发表于 2021-8-31 22:22:21 | 显示全部楼层 |阅读模式
Anyone had any experience with a filler alloy 4943?  It's claimed to be approaching 5356 in 'as-welded' strength and retains the ease of welding of 4043?http://www.thefabricator.com/article...a-filler-metalI've always stayed away from 4043 after some cracking on 6061-T6 in the 1970's, really distrusted the alloy except for cast parts. Now this article and tests seems to show this newer filler alloy to be a real viable product?Cheers,Kevin Morin
Reply:Yes, it magical actually. Only downside is it won't Anodize. It flows faster than both 4043 and 5356. For me and time is money.It still is less ductile than 5356, but is less prone to porosity if that is a problem.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:It was interesting to note in the article that the increased strength can allow one 4943 fillet pass to achieve the same strength as three passes of 4043. So the HAZ would be far smaller and much less total filler would be required.
Reply:Not to mention the time savings.
Reply:4943 has 25% increase in UTS and 50% increase in Fy over 4043.  Local LWS unable to source under 100# lots.  Will see if Terry's contact in CA can ship 10# in 3/32"."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:The green monster airgas actually got me 1# spools for my spool gun in 2 days.    I was just as shocked as anyone.       I gave them the part number and the right part showed up.   Still havent welded with it yet thoughVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I have been trying to get some in LA but no luck they all say it has to come from back east. SIMS, Cameron, Airgas. The Airgas in Sioux Falls SD said they have it near them in IA and Faribault MN, both of which are a short drive away. The problem with these big cities is that the people who make stuff are too diluted by people who dont. So it's hard to find good suppliers. I can't figure out why people working in welding shops are not more familiar with new technology though.On a similar note, I need some aluminum laser cut. I called my buddy in South Dakota to see if I could get a quote from there. He said there are three laser cutters near him and he would shop it around. This is in a town with 10,000 people. The quote came back at half of the cheapest quote from LA. No wonder the economy here in CA is in trouble. This is almost as bad as Minnesota...
Reply:Terry where are you buying this stuff?
Reply:Originally Posted by atgTerry where are you buying this stuff?
Reply:Originally Posted by atgNo wonder the economy here in CA is in trouble. This is almost as bad as Minnesota...
Reply:Originally Posted by 7A749It's made right here in Traverse City Michigan.Took forever to get 10# in of 1/16" & 3/32" They are only a couple hours away from me
Reply:Dave said he would check bit it sounded like maybe 40lb. I only need 10 or so.
Reply:Originally Posted by shovelonSims. Call the Sylmar store, ask for Sal or David and tell them Terry from Jaytech said to call.
Reply:Originally Posted by atgDave said he would check bit it sounded like maybe 40lb. I only need 10 or so.
Reply:The local Robert'sOxy is hook'n me.  10# of 3/32" at $5.75/lb enroute from GA today.  Note:  Maxal is available from Hobart/Miller distributors.  Adding Robert'sOxy to my GTG list.  "Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by ManoKaiThe local Robert'sOxy is hook'n me.  10# of 3/32" at $5.75/lb enroute from GA today.  Note:  Maxal is available from Hobart/Miller distributors.  Adding Robert'sOxy to my GTG list.
Reply:Originally Posted by shovelonSo what size are you coveting?
Reply:Cameron can get it also from rancho Cucamonga for $7.18/lb. Seems kind of high.
Reply:For Southern California guys, Sims finally called back and said they would do a 10lb order for 7.18/lb in 3/32. Prepaid cash if no account, delivered to store for pickup. They would not drop ship to my house.
Reply:I ended up buying 3/32 and 1/16 from Airgas Sioux Falls. They drop shipped it direct to my house. $100 minimum order so I got 10lb of each. Mind you this is after asking the airgas on Jefferson to please do the same thing, and having them refuse Call Airgas Sioux Falls and ask for Bill. He expects it will ship from California to me in California.
Reply:Cool.When do you expect it?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I'll have to call him back and get the tracking number. I just finalized the order yesterday afternoon. Would have gone with sims but honestly it's rare that I can get there during business hours. They are not open Saturdays near me.
Reply:Originally Posted by shovelonCool.When do you expect it?
Reply:10#.  Arrived today.  Sweet.  Tomorrow, we burn-in. "Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Is it just me or is this 4943 a bit easier to weld with than 4043? It seems to melt or flow a bit more easily.Originally Posted by atgIs it just me or is this 4943 a bit easier to weld with than 4043? It seems to melt or flow a bit more easily.
Reply:Frankly i did not expect that. It makes a big difference on 1/16" material, even for a hack like me.
Reply:Not only does it flow like butter, it is also stronger. I love 4943 use every time I can
Reply:Originally Posted by atgSeems kind of high.
Reply:Yep. 4943 is my drug of choice. Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2026-1-1 09:34 , Processed in 0.075854 second(s), 18 queries .
