WTB: SA 200 Marvel carb/governor linkage parts
发表于 2021-8-31 22:22:13 | 显示全部楼层 |阅读模式
I also have this posted on the AWS site.  I have two SA-200's here that are missing governor-to-carb linkage parts.  I'll try to explain as best I can.  I can take a picture of what I do have if it'll help.  These are redface era machines with Marvel Shebler carbs.Machine 1 needs:-The short arm that locks to the throttle shaft on one end, and that the carb end of the long governor rod pivots on.  Machine 2 needs:-The same arm as above, and...-The long governor-to-carb rod with pivots on both ends.  Pretty sure this piece is still available aftermarket, but if you need to get rid of a good used one at a decent price, I'll buy.I can pay with paypal or whatever you prefer.  Can provide references I've dealt with on this board if you'd like.
GMT+8, 2026-1-1 15:12 , Processed in 0.100281 second(s), 18 queries .
