I was looking for a good cut off saw...
发表于 2021-8-31 22:22:06 | 显示全部楼层 |阅读模式
And found this on Ebay...not sure how I'm going to fit it into the garage just yet. At $202.00 I think it was too good to pass up...BTW, it's got a 1hp 110/220 1ph motor...opinions? Attached ImagesMillematic 210Hypertherm 380Everlast 200DXHF 110v Inverter
Reply:Nice find!! I think you'll like it better on 220v. There's an amazing difference in torque between the two voltages.                                              MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Much as I hate abrasive saws I would have jumped on it, good score.x2 on the 220v if you can do it.
Reply:Thanks for the input! I do have 220 available, I'll give that a try...1hp does seem a little lite for this. I expect this will probably be the last saw I need to buy in my lifetime!Millematic 210Hypertherm 380Everlast 200DXHF 110v Inverter
Reply:Figure out how to gear it down and use dry-cut blades on it.
Reply:+1 on the dry cut blades.  Switched from abrasive cutoff saw to the dry cut and haven't looked back.
Reply:Changing the pulleys down to an rpm lower than 1700 could be done I never thought of that ..since most of today's abrasive saws are direct drivethe question has never come up ..to me at leastBut since i bought my rage 3 i have not looked back eitherthe old abrasive saw sits in a corner collecting dustBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:very nice find. i gave one of my abrasives to my cousin and the other like  Killdozerd's sits in the corner collecting dust, but not anymore abrasive dust.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:That looks like a fantastically beefy saw... I have nothing against using abrasive cut off saws, outside...
Reply:ttyR2: Since it's a belt driven blade I imagine the pulleys could be changed and the speed reduced...what kind of dry cut blade could I use? I've only used abrasive blades...kustomizingkid: Agreed! Note the casters on the stand...outside it will go!Millematic 210Hypertherm 380Everlast 200DXHF 110v Inverter
Reply:You would need this blade for a 10 inch they also make 14 inch bladesfor the evolution rage( i forget the number) but it's the chop saw modelhttp://www.amazon.com/CARBIDE-TIP-MI..._bxgy_hi_img_bHere is the thread about the Evolution Rage dry sawshttp://weldingweb.com/vbb/showthread.php?t=60147Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2026-1-1 15:12 , Processed in 0.078552 second(s), 18 queries .
